2000 for gauges is way to much i bought an aem wide band and boost built in 1 gauge omes with everything you need to install it. Mine cost 330 from pepboys definitely worth the money
How hard was it to install yourself? THX
The mag is an easy install. We did it on one day.
The lift to shift comment earlier is a good one. Id contact both companies RIPP and Mag and see if they can swear you wont have the lift to shift problem. If they tell you it will be a non issue, then you can decide. If one says no prob, and the other wont, there's your answer.
Thats a good suggestion.. Thank you. How important is the person doing the tuning at the time of install in the whole process? The Maggie dealer is quoting me four hours of tuning at $125.00 per to tune. I thought the programmer unit did the actual tuning or I am missing something here? Money is not really the issue, but I hate being taken advantage of..
