Results 1 to 10 of 252
    To avoid confusion, I'd like to clarify that the dyno chart posted here is for the 3.8 turbo kit with the 12psi kit added to it. Here's a dyno chart comparing the stock 3.8, the "standard" turbo kit, and the 12psi kit:
    Can't wait to see what the torque curve looks like for the 3.6 kit!
    Excellent correction.
    Welcome Pickles. We are excited to have you here. Credit where its due, Pickles contacted us weeks ago and turned us on to Prodigy's Turbo.
    Pickles's point is that there is the base kit that makes 8psi and around 275 wheel horse power. Then this 12psi kit pushes the power over 350 wheel horse power.
    There is so much to learn about turbos vs. superchargers. The obvious difference is that Superchargers run off the engine belt, and the turbo runs off the exhaust, and is considered more "effiecent". What we didnt know was how their power curves climb off the charts.
    Its going to be interesting to see how they do in our Jeeps!
    If designed reasonably, there shouldn't be much noticeable lag. The infamy of turbo lag comes from large turbos on small engines used to produce huge power at high RPMs. Prodigy seems to have targeted more to the mid-range RPMs for the 3.8, and I'd expect they'll do something similar for the 3.6. Since the 3.6 is already stronger in higher RPMs in stock form than the 3.8, they may have even been able to target slightly lower RPMs for peak turbo efficiency on the 3.6 while still hitting impressive peak power numbers.
    Based on general torque curve shapes, I think the turbo will "feel" kind of like the RIPP centrifugal supercharger in the lower half of the RPM range in that torque gains will ramp up, but it will ramp up much more quickly. In the upper half, it will "feel" kind of like the Magnuson roots style supercharger in that it will be steady strong (relatively constant) torque all the way through, except it will be quite a bit more than the Magnuson. Kind of a hybrid between the two supercharger types.
    Is it there yet? Is it there yet? I can't stand the suspense!
    The other issue is heat in the engine bay... I can't wait to see what their plan is for that.
    Maybe you guys could put thermometers in the engine bays of all 3 trucks and see who is hottest?
    thats a great idea.
    i wonder where we can find some thermometers that are wireless, or with wires, that would make that kind of test work.
    more research? No problem.
