I can't wait to see how those pipes are routed. It appears like a large portion of the front of the jeep will have to come out to do the install.
Don't they advertise the kit as bolt-on or nearly bolt-on? That can be loosely used, I know, but that seems fairly extreme. Like you said, we'll know when the instructions come out.
I recall the RIPP supercharger was "bolt on" basically, but that install required some cutting and modding, and a lot of removal of this and that. Only time will tell!
Looks like they do describe the 3.8 kit as a "complete bolt on Jeep turbo kit". I think "bolt on" for major mods like a turbo kit has a bit of leniency to mean "a competent DIY home mechanic can do this in their garage/driveway with basic tools that you probably already have; no plasma cutter or welding required"
If this thing is so close to release, You guys should be able to at least get a copy of the instructions.
Climb in thru the bathroom window or something. I read this site because you manage to get this stuff first.
