Stupid physical reality getting in the way...
Do you know which "stage" kit you'll be getting?
The different stages could also widen the target audience in that a lower boost "stage 1" kit might actually be better for more serious off-roading/crawling, because there wouldn't be as much of a sharp rise in torque in the mid RPM range. This will be interesting.
- You may not post replies
- You may not edit your posts
