I think a simple turbo blanket would solve your heat concerns without relocating anything: http://ptpturboblankets.com/why_turbo_blankets.php
The fluid container should not be an issue because that's on the "cold side" of the turbo.
Yeah..I was reading a lot on their site and mentioned the turbo blankets back on page 2. I think you'e right in that the blanket would go a long way, even if only to alleviate concerns. The picture is also at an angle, which makes things seem closer than they really are under the hood. Pretty excited now!
this kit is completely going into the unknown on power.... A little birdy told me that the base kit might ship set up for 12 psi. (the amount of their top tier kit for the prior model 3.8 wrangler)
They have a lot of confidence in the pentastar and are not afraid of the extra boost. Their upgraded model, may be well past 12 psi.
