Here we are mocked up. Did it in about 10 min.
Once mocked up, I put the threaded rods in, you see im short one. Thats where I hit the wall today.
This only holds it in one direction, so I added some pipe clamps
Finally I put on the corners and bolted them
I made everything hand tight and then put the square on it, and I couldnt find anything to correct. Thats how tight the lazer cuts are. Normally I have to mod everything a little, not so here. Very refreshing. Now if I only had another threaded rod.......
