The RK will be taller. You will get 2 inches in the front, and 1 inch in the back, (over rubicon height)
If your truck is not a rubi, you will get more lift from where you are....
Leveling - keeps same basic height, and brings up the nose. "level" but not look stupid with your stock tires. The inch will not be a drastic change
Lift- This is to fit larger tires. Will level, and lift, and still look ok with Rubi tires, at a minimum. More noticable change.
