So the plan with this build was to keep it on a budget.
The question was, what do we have that we can keep?
answer - flares, wheels, tires, shocks,
We wanted to keep from changing one thing, that forced us to change EVERYTHING. Enter the RK 1.5 springs.
By using these springs, we could keep the upper and lower control arms, trackbars, even the shocks dont NEED to be changed right away. It allows the budget to recover before making the next move.
The tires are the 255/75r17 Rubi Stock tires, so they are aggressive enough for now.
The first step was lifting the truck far enough to release the spring. We tried to avoid disconnecting as much as possible but in the end, Shock, swaybar link, all had to be disconnected to get the droop necessary to change the spring.
