Results 1 to 10 of 47
    To anyone attempting to do the exoskin install I highly recommend getting every single bolt in and threaded before fully tightening any single bolt. If you don't there is a good chance one of them won't get started and you'll have to back them all out anyway! Start tightening in the middle and work your way out and down.
    what did you seal the nut certs into the body with? some kind of glue right?
    The nutserts crimp themselves onto the body as you mount them. I painted the inside of the drilled holes and each hole was an EXACT fit, 17/32nds. The tighter the hole, the better the rivet nut would grab onto the body. It takes a LOT of force to install a 3/8 16 rivet nut!
