Metalcloak's setup is unique - the shocks are probably the most spectacular part of the whole deal both visually and functionally.
Check out how good looking these were, even in the box!
Name:	2013-12-06 10.09.14.jpg
You can read about the shocks all over the place, but the concept is that shock shafts extend both north and south out of the shock body giving twice the stroke of a normal shock. As it compresses, the short shock body doesn't serve as your limitation for compression or travel. Pretty cool.
They're pretty fat shocks as shocks go, but Metalcloak has bolt on mounts included that let you slap them in like a no-brainer. There are a few adjustments you make to keep them from slapping around, but they aren't too bad.
Metalcloak also zinc plates most of the hardware for corrosion resistance. The shock mounts are no different but check out how beefy some of the parts are compared to stock, and adjustable too.
