Results 1 to 10 of 64
    Goodyear Duratrac
    Here is the first aftermarket tire I've installed.
    I wanted to maintain the ride as best I could and wanted something good for snow.
    The duratrac has the snowflake that signifies that its a serious winter tire, and it maintains the aggressive look of a Mud terrain tire.
    MUD -
    Ehh not great here, the type of mud makes a difference. If its not super soft, the duratrac will kind of float over the top with its wider tread. In deep wet mud that you sink in, they gum up. I never got stuck with them, but if i knew i was up against deep soft mud, I might go another way.
    SNOW -
    The snowflake means they are good, and they are. The compound is softer so when they are cold they arent as grabby as they are warm, but they are sure footed in the snow and ice. I once tried to climb a steep driveway that had 10 inches of untouched snow on it, and failed. It was an extreme test. Im not sure any tire would have made it up.
    RAIN -
    You wont even notice rain with these on. Wet traction is superb.
    SOUND -
    Silent. The tread pattern and the softer compound together equal complete on road silence.
    RIDE -
    Also superb. If your trying to maintain the best possible ride, this tread pattern and rubber compound is hard to beat.
    BRAKING -
    I dont remember ever really being in a dangerous situation with these tires where I jammed the brakes, but the compound and amount of rubber on the ground (small voids) lead me to think that they would stop very well.
    RECOMMENDATION -
    Yes, I would recommend them to anyone who was looking for a SMALLER tire. they don't come in a real 35 size. Their largest is 34.4 and they didnt measure to reach that mark. If you want a real 35 or 37 you have to look elsewhere. HOWEVER. IF goodyear did make them in larger tire sizes, they might be a force to be reckoned with.
    Pros - Good at almost everything
    Cons - Cant get larger tire sizes.
    Bfg km2
    These are Black Betty's tires at the time of this posting.
    We HAD to go to 37s to show them crammed into a 2.5 inch lift. I was terrified of losing the power we had gained with the RIPP supercharger. I searched high and low for the lightest mud terrain tire, and the second thing I was looking for was sound, followed by ride quality. These do not disappoint in any of those categories.
    Here we go -
    MUD - Its the KM2's natural habitat. These things fling mud all day long. Nothing seems to stick. I dont live in the mud, but when I have been in it, I've never gummed them up. AND Im not hard on the throttle.
    SNOW - They are not snow tires, but I have driven to Maine in a blizzard and they never slipped. For fun I would toss the truck in deep snow, and never once was she stuck. You cant drive like a fool on any mud tire in snow and icy conditions, but if you drive it like you know your wearing mud tires, and are careful, They could be 4 season tires. We got about 50 inches of snow overall in NJ this past winter, and I never wished for snow tires. The KM2s handled the poor conditions admirably.
    RAIN - Also very good. They have large voids, so hydroplaning isnt really a concert, the lugs get pressed to the pavement under the weight of the truck and the voids spill the water out the sides. Wet traction is very good.
    SOUND - This is where the KM2 stands alone. So much research has gone into the development of the tread pattern that they can be one of the most aggressive mud tires available, but STILL are very quiet. They were silent up to my first tire rotation, now I hear them a little, but only when I'm trying to hear them.
    RIDE - You will feel the lugs when you slow to a stop sign, but you get used to it quickly and its in no way jarring. That is a tiny downside to the incredible highway manners these Mud Terrains offer. 7 hour road trip? No problem. I did one in January (7 hours 1 way) and on the way back, I did the first 5 hours before turning the controls over to the co-pilot. I could have done the whole 7 hours at once. Its a joy to cruise on them, as at speed they behave excellently.
    BRAKING - This was a surprise. I assumed with the large voids and big lugs, this would be the category that would the KM2 would fail. And if I had to guess, without experience with the tires, I would guess this would not be their strong suit. HOWEVER. I was in a situation on the 37 inch KM2s where I had to jam the brakes, and they bit the pavement like I couldn't believe. They really saved Betty's paint job. I was certain i was going to plow into a car in front of me that had been cut off and jammed his brakes. (and I was probably driving faster than I should have been.)
    Recommendation-
    If you want big tires, these are the tires. Yes they are a little more expensive. But tires are a mod that you feel every time you drive. On road, off road. Tires are always under scrutiny. Power? if you want to keep as much as you can, you need to keep the tires as light as possible. The lightest 37" tire available? The KM2.
    PROS -
    Everything Really.
    CONS -
    They are expensive.
Name:	black betty getting off lift.jpg
Name:	weld racing bfg 0.jpg
    Hey JeepLab... I've been looking into upgrading to 37's and I've always remembered your posting on these tires. These tires interest me a lot but I have a question on the width. My Micky T's Baja ATZ's have a size written on them of 35"x12.5x20", however, when I measure the tire, they are actually 13.5" wide. I REALLLLLLLLY like the look of the 13.5" width vs. other 12.5" widths I've seen. On your KM2's, are they measuring at 12.5" wide or are they coming in wider? I see they offer a 38" but it is 14.5" wide. I like the 37" because they are only 4 lbs heavier than my 35" ATZ's, whereas the 38" is showing 16 lbs heavier than my ATZ's.
