Here's what your pipes will look like if you don't follow up and re tighten the system.
You can see where the clamp is, and the black marks are carbon. They are there because the exhaust is coming out. Thats the signal that your leaking exhaust.
This can also lead to error codes from your truck.
Simple answer? Get under there with a ratchet and tighten them as much as you can.
