We are going to change Betty to 4.88s later this month for a more aggressive trail set up. I'll let you know if I like it less.
Here is all the Yukon Gear we are going to install.
Its their chromoly axle shafts and 4.88 gearing. Its all the complete axle seal set up.
Got it all from randy's so its all from the same manufacturer and should all fit together perfectly.
Name:	Yukon Gears Axles  (3).jpg
Name:	Yukon Gears Axles  (8).jpg
Name:	Yukon Gears Axles  (10).jpg
Name:	Yukon Gears Axles  (11).jpg
Those yukons are SEXY.
