If anyone out there wants to tackle this mod. Find a GOOD shop. AND you want to see the truck, AFTER prep, and BEFORE wrap. They have to clay bar and polish the entire truck before the wrap goes on. You want to see your truck perfect? You have to see it before the wrap goes on.
Even if you cannot go back to see it before the wrap. Tell the shop that you do want to see it after prep and before wrap. That way they will make sure its perfect. Then you can let them wrap it. Check xpel.com for one of their installers. Thats best for the 10 year warranty.
I went on xpel.com and found a very high rated dealer. This guy spent forever prepping the paint. He clay barred the paint several times, then even repaired a few scratches. Then the vehicle gets washed several times and the application area stays damp to prevent dust. In between body panels, they actually wash the jeep again! He was telling me how static and air movement will let dust find its way to the paint no matter how hard you try to keep it clean between panels.
What I thought was cool is that my installer actually took the CAD designs and modified them to allow himself more material to tuck under the edges and around corners of panels. A good installer probably means the difference between excellent and average results.
