This is cool. I can weld too. Im not sure I'd do some thing as dangerous as a coil over mount. If that goes, you really do have a problem. (and might die)
The rear truss however, I'd tackle. Although, that is a steel to iron weld... so not beginner stuff.
Obviously they are not useing flux core at Rock Krawler.
Im using some flux core wire now and cant seem to get to penetrate 3/16s steel
- You may not post replies
- You may not edit your posts
