Results 1 to 10 of 15
    I should mention that the nutserts are 6 months old.
    Here's some shots of the nutserts before I cleaned them.
    The inside of the nutserts looks gross also, but I've decided that its the anti-seize that we put on the stainless steel bolts that hold the flares on.
    The real concern here, is that if the corrosion eats through the outer ring of the nutsert, it will allow the nutsert to spin in the JK's super thin sheet metal. That would mean I'd be in a situation where the flare is half on and half off with the stainless bolt halfway out. Then I'd have to cut it off and drill out the nutsert.
    Any way you slice it, you need to make sure to prevent that sort of problem rather than deal with it.
    Here's my solution.
    Im going clean the nutserts as best I can with a waterbased degreaser. In this case, its going to be "simple green". I think it will be gentle on my paint, while cleaning the nutserts.
Name:	simple green.jpg
    Then once they are as clean as I can get them, Im going to POR-15 them to seal out the elements.
    Here are the shots after I rubbed them with the simple green, on a towel first, then on a cotton ball that i jammed into each.
    I should note I cleaned the section that I simple green'd with carwash spray.
    I did not spray anything directly on the section. I didnt want to have any sort of moisture getting inside the body panel.
Name:	Cleaned Nutserts 1.jpg
Name:	Cleaned Nutserts 2.jpg
    Here they are painted.
    The technique is thin coats, but do a few of them. Also, cover up. gloves, long sleeves, if you get POR15 on you, its staying on you.
    If you get it on your garage floor, its staying on your garage floor. They made it permanent on purpose.
    The first coat, I could kind of see through. Then the second I got full coverage. I might do a third coat.
    One other note, mix the POR 15 in the can, but then pour it into a paper cup. The brush will pick up contaminants when you brush it against rust and corrosion. You dont want to put that brush back in the can.
Name:	POR 15 nutsert 1.jpg
Name:	POR 15 nutsert 2.jpg
    Nutserts are one thing you do NOT want corroded. That makes for BIG problems. And these nutserts are the same as poison spider and metal cloak etc.
    They should make them out of steel and tack weld them to the body. Then you just spray paint the whole thing and your good to go.
    I think the POR15 is good in this case, but only time will tell. (you probably won't ever take the flares off again in the future tho)
    That is serious corrosion for a 6 month period. Por 15 is an amazing product and will prevent corrosion. Period. This has me freaked out about mine front and rear as I have many more that hold the side of my jeep together!
