Results 1 to 10 of 19
    Anyone do this with a hammer?
    Im told you should bash them in, you preserve the integrity and keep moisture out.
    I've seen them hammered. Its not a clean look and I'm not convinced it does more to preserve integrity than JB Weld...which is very strong.
    Tonka is hammered. It looks fantastic. Might be the best pinch seam ever. Its very well bent in... You might think it was stock.
    Here is tonka's pinch seam.
    Bent in and undercoated. (filthy in this pic)
Name:	tonka pinch seam.jpg
    Did you do that with the wheel off? I can't imagine how you could get enough swing to bend it that much, unless the wheel came off. Is that a stock Ruby rail with another tube welded on it? or something aftermarket?
    Here's mine before removing the wheel liner and flattening my factory fenders. When my new lift comes in I will take the trim up a little further and make it a little nicer.
    FIRST POST!
    Welcome Buddy!
    Thats a well done pinch seam. I dont think you need to do anymore to it. I wouldnt cut too much body.
  8. #8
    Thanks. It's good to be here. With the liners out it could use a bit more trimming to even it out and make it more flush.
