I just cut my seem.
I got some dirt in it, then washed it, so that foam inside was wet maybe... then I packed it with JB weld,
Am I going to rust my body out?
It's hard to tell. You should probably have let it dry before the JB Weld. A little dirt wouldn't hurt it any. To be on the safe side you can always drill a small hole through the JB Weld and let it air out for a couple days and then patch the small hole with more weld.
