Results 1 to 10 of 19
    Here is tonka's pinch seam.
    Bent in and undercoated. (filthy in this pic)
Name:	tonka pinch seam.jpg
    Did you do that with the wheel off? I can't imagine how you could get enough swing to bend it that much, unless the wheel came off. Is that a stock Ruby rail with another tube welded on it? or something aftermarket?
    Here's mine before removing the wheel liner and flattening my factory fenders. When my new lift comes in I will take the trim up a little further and make it a little nicer.
    FIRST POST!
    Welcome Buddy!
    Thats a well done pinch seam. I dont think you need to do anymore to it. I wouldnt cut too much body.
    Thanks. It's good to be here. With the liners out it could use a bit more trimming to even it out and make it more flush.
    Show us a pic of the whole truck!
    Ask and you shall receive:
    are those flares custom cut?
