Results 1 to 10 of 28
    The correction begins.
    I just drove to RK this past weekend with bare flares because ive been trying to get them fixed.
    Now betty is back and the flares are stripped and back in the oven.
Name:	Jeep Flares Oven 1.jpg
    The picture Ross posted was of the flares being out-gassed of all oils and contaminates. A little info about out-gassing: Aluminum and other softer porous substrates require an "out-gassing" or "bake-out" procedure to force any contaminants like oils, chemicals or grease to the surface of the substrate which can then be cleaned or blasted off. The out-gassing procedure requires the parts/substrate to be heated for 45 min @ 450*F. If this step is not taken I can guarantee there will be imperfections in the final finish such as tiny bubbles or holes in the finish.
    Byrne Coatings
    27 McDermott Pl.
    Bergenfield, NJ 07621
    V: 201-477-0079
    chris@byrnecoatings.com
    www.byrnecoatings.com
    Quote Originally Posted by Byrne Coatings View Post
    Good information for anyone taking things to the powder shop. Nothing better for the consumer than to be education prior to a purchase. Info like this allows us to judge whether or not a vendor knows their stuff!
    This is horrendous. You can see why you couldnt wrap this. Gross.
