Yes.
BUT - More pressure means more power, but also more strain on engine parts.
So overall the answer (as i understand it) is
the extra psi in higher elevations, is more of a correction. You can use it like theGrinch uses it, with a huge smile on your face, but is the extra pressure worth it on your engine at sea level?
At altitude, the higher pressure is leveled out by thinner air.
