Is this popping when you turn left/ right/ both?
What do the wheel sensors cost? Were these the same lights you got when the tire wore through the wire of the wheel sensor? Can we return the wheel sensors if that turns out not to be the problem?
If you are following this nightmare, here is the most recent update. Yukon sent me a new axle all pressed together correctly.
We installed it without a hitch, and now rather than the abs and traction lights coming on some times, they come on all the time. I didnt make it out of the driveway.
I dumped oil over the berring before intalling it, so I may have splashed some oil on the sensor. Took it out cleaned it, put it back, same problem. Took it out again, more oil on it.
Im going to let it settle over night, since im exhausted. and fire it up in the morning. Hopefully this problem will be over.
My weekend Jeep hobby has officially bled into the week.
Heres what Ive figured out. We changed all the axle components and the lights came on right away now. Im thinking, I've taken this sensor out 20 times now, i must have just really broken it.
upon further inspection, it appears the tone ring is pressed in backward. Easy to overlook....The sensor does not overlook it. It freaked out right away. pics coming
