I assume you are asking about the glowing object in the middle left side of the photo. If so that is a license plate over 650' away from where I am parked. The ground is about 5' lower than the road surface. I will try to find a dark level place with a building at a known distance away so everyone can get a better idea of the output.
Here are a few more photos of the Raxiom H13 led headlights. The building and fence are approximately 214' (took an actual measurement this morning) away.
dims
brights
These were from about 20' away
dims
brights (posted wrong photo originally)
You can see how the dims are more bell shaped and the brights are flatter.
I will see if I can get my camera to mount and get some video going down the road. After driving with them, I have really ome to like the whiter light. Reflections from street signs don't seem to mess with my eyes, plus you can see a stop sign several hundred yards down the road. While you can't make it out, you can see the light clearly reflecting back. We had a little fog last night and they seemed to cut through the fog well without having a lot of flashback. Pleased with the purchase.
Well after driving with radio running and headlights turned on there is interference with the radio, at least for station at great distance on fm. My stubby antenna could add this issue. I have heard of similar issues with hid kits.
I had my truck out at night last night for the first time. I love the truck lites.
Mind you, im coming from stock with a bulb upgrade, this is a new world from there.
Other people complain about artifacts with the trucklites. Personally, now that Ive seen them at night its a non issue. The crossing of one bulp and the other makes a bright spot out in the distance about as wide as the lane you are driving in. So its a little extra brightness right where you need it.
Aiming- I have them set normal, and i think they are high, People werent flashing me last night, but the high beams were useless, as they were above the zone where I wanted them.
The trucklite aux lights in the jeeps fog location is also a VERY big improvement over stock.
Im going to use some fluffy weather stripping to try to reaim the beams back down to the ground a little. Its to be expected with a lift.
Is JW speaker getting in on this?
Im trying to decide.....
X2 on jw speaker....
New member coming from WF. Saw this place after researching the turbo project.
I am currently investigating a HID projector setup for the JK. I have sourced a harness, new housing with a projector placed in it and an HID system. I have everything on order and hope to have somthing together by the end of the weekend. What I have priced is much cheaper than the LED lights like TL and J.W.. I'll post some pictures this weekend when I get everything together
