Results 1 to 10 of 12
    Pickles is on FIRE!
    but overall. does the throttle response feel different? or just a smooshier pedal?
    I ask because since i geared BB, I have had to use more leg to hold the pedal down to maintain higher speeds. This may be the solution to turn her back in to the long distance cruiser that she used to be. (she still cruises pretty damn good)
    I see a benefit of having a "stiffer" pedal while off road. While bumping and jarring around as jeeps do, the extra pedal tension would prevent accidental heavy acceleration. In other words, a lighter pedal, with increased throttle response is more sensitive to the small movements.
    Now that you mention it, I notice the pedal's requirement for some force. That being said its not an issue for me (maybe my big feet help). I'll be interested to see how this work for you in the real world. '
    Also..not sure the spring rate..the more open factory smaller spring could be stiffer than the smaller, more tightly coiled spring. I"m sure a simple device could be used to measure the force to compress both to compare. Too many variables for me to wrap my mind around. Seems like trial/error would be the best way.
    I'll wait for pickles results then copy cat!
    It might be worth mentioning that if you put a new spring in there, make sure the new spring doesn't fully compress and bind up before the pedal reaches the end of its travel.
    yikes, imagine the springs bind up an the pedal stays down? that is scary.
    You guys are brave, screwing with the gas pedal
