Is the high altitude pulley going in this weekend?
For all you people having problems with surging my ripp was surging slightly until i dug into the problem more a preset tune is only as good as the person writing the tune. You cant blame the companies for having one truck with a bad tune you have to remember every truck is different and runs differently. To really get your jeep running 100 percent install a wideband gauge so you can monitor your air fuel ratios which is critical to a forced induction motor and pay a local tuner to dial in the air fuels spark fuel delivery at every point in the rpm band so you dont detonate your motor under boost conditions and youll know 100 percent your truck is dialed in and can handle what youll throw at it
A wide band gauge is useless if you don't have the knowledge, skills, and tools to adjust the tune of your vehicle based on the gauge readings.
How much does it cost to have a tuning shop dial in the tune for street driving?
Ive got the AEM wideband gauge and AEM boost gauge that needs to be installed. (Purchased them from Dan from Prodigy when i purchased the stage 1 kit) The shop will be installing this as well when they install my stage 2 and get everything dialed in. Hopefully they can do this Tomorrow before i leave on tuesday for a week..
My tune was 650 my jeep has never been more solid thru out the power band no more surging or hesitation
