A word about mileage. Ignore that mileage on your dash. When you calculate mileage, fill your tank and set the odometer to zero.
Then let it run through the tank completely.
Then fill back up. If its 20 gallons on the second fill up, you divide the odometer by the gallons.
So if you got 300 miles, on 20 gallons, You got 15 MPG.
Only real way to see what your getting.
(assuming your tires are set correctly with your diablo unit, dont get me started about how many of us are wrong about that, your nav should match your odometer. But you need a long drive to be absolutley sure)
Great thread! Carry on!
  Reply With Quote Originally Posted by Icheer4beer
