0-60 time. I downloaded a speedometer app and confirmed that my speedometer is pretty accurate. I drove around and found a flat stretch of road. I don't know what the truck weighs but it's basically weights the same as a JK-350 from AEV plus the hemi. I had a half tank of gas under the truck and 10 gallons in the fuel carrier behind the spare. The hi-lift jack is on and my recovery gear is in the back which weights about 75 lbs with straps, shackles, snatch blocks, etc. The lockpic timer sets to 0 at complete stop. The instant you hit the gas the clock starts. I have no idea how accurate it really is. Here's the result.
