Results 1 to 4 of 4
    This is the greatest trail riders accessory ever!!!
    The Wolo 4000 or 4000-2 12 Volt PA System with sirens for vehicle--
    The difference the 4000 series has a 50 watt speaker and the 4002 as a 80watt speaker.
    Now, this is the more expensive Deputy System-- but you get the idea. NOW, think of the trail riding fun you can have as you do something like this:
    I'm going to have so much fun when I install this into the DUKE.... I had to make some modifications to the installation-- i.e. a separate 12volt battery since I use 2x12volts in series to create 24volts. However, I'm changing the wiring harness soon--so, I'll add a step-down inverter into the system so I can step it down to 12volts for a CB Radio, PA System and of course a an recharging port for my IPOD. I'm going to set up the sound system through two sets of Aviation Headsets-- the cab is about 85 Decibels.
    But getting back to the point-- think of the fun one can have on the trail mocking and taunting your fellow off-roaders. I'm really excited about this modification to my truck. I'm seeing hours and hours of enjoyment with driving around towns, off-road parks, cities and so on with this toy!
    It perfectly complements this...
    Think about it-- you're on the trail-- you have a cigar, a viking helmet what do you need? Well a PA system to taunt and have fun with your trail buddies!!!
    cute, but I've never had a CB, and only missed it in MOAB.
    I think the best trail accessory is the VIAIR under hood constant duty compressor. Ive used that plenty, even to blow up an air mattress when camping because I bought the wrong mattress that didn't come with a pump. Super clutch.
    I don't sleep outside-- I dont' like bugs. It's not a CB it is a PA system-- It is for psy-ops while off roading. I already have an air compressor on my truck... It boosts the brakes and operates the front axle disconnect clutch. It will soon operate 3x ARB RD33 Air lockers and an air-dryer unit from Wabco. So, I've got the air covered. I just don't have a way until today when it arrives a means to engage in Pys-Ops with my trail buddies or have fun in parades!
    Give a little nod to Oddball and have some fun while you're at it.
