Originally Posted by JeepLab I think you might be screwed regardless with 4.88s. You might not do 60 in second gear.... Pickles? the math? Depends on tire size. I hit 64 mph at the end of 2nd gear with my 3.21 gears and 28.5" (actual size) stock tires. So a quick calculation shows that you would need at least 40.6" (actual size) tires to hit 60 mph in 2nd with 4.88s
