Very cool. Is it keyed to match the doors?
			Found the link below and tried it and it worked out pretty good. You basically have to take it apart and cut 1/2" strip off the housing and the latch and then weld them back together. Then two new holes drilled right above the intercooler mounting holes.
http://www.jk-forum.com/forums/jk-ta...lock-216763/#b
			i like it. i hate the idea of someone messing with my engine.
			Yes the mopar hood lock gets keyed to your key the first time you turn it. I had it from before so I modified it and it worked out.
