Ok, I was trying to let this play out without weighing in...
Here's what I've got, You should consider a 2.5" lift.
There are more and more options to pick from. here are the benefits -
Low Center of Gravity
Better Fuel Economy
Still fit the 37s in
Fits in Garage. (although im not sure a 3.5 with 37s wouldnt)
If your not a serious wheeler, I can say that its got plenty of articulation. (RK 2.5 X-Factor)
If you are a serious wheeler, I can also say, its got plenty of articulation. (RK 2.5 X-Factor)
I wheeled moab with a 2.5, and there was nothing the lift couldnt do.
- You may not post replies
- You may not edit your posts
