Results 1 to 10 of 47
    what did you seal the nut certs into the body with? some kind of glue right?
    The nutserts crimp themselves onto the body as you mount them. I painted the inside of the drilled holes and each hole was an EXACT fit, 17/32nds. The tighter the hole, the better the rivet nut would grab onto the body. It takes a LOT of force to install a 3/8 16 rivet nut!
