The good news is, if you just geared, you have to change that fluid regardless. So correcting the gasket problem isn't that bad.
When you take the cover off. Lay in on your kitchen counter and make sure its perfectly flat.
There are a lot of welds on it, and each weld adds heat and can warp the metal. If its not perfectly flat, you need to get the manufacturer on the phone.
I thought the welds were cool on the diff cover... Now on second thought, it seems that they are each a possible point of failure.
