Results 1 to 10 of 43
    Do these trusses add a lot of weight?
    They don't. The sides of each truss is .130 and the top is 1/4 steel. Total weight of the front is under 11 lbs.
    The rear is smaller, so will be less.
    I didn't notice any difference in drivability with them installed. You don't even know they are there.
    I concur, these aren't terribly heavy and the benefits are tremendous. Both of mine came in one box and I was able to pick it up easily (was prepared for something heavy). I'm pretty sure that the welds give it the necessary strength.
    Those holes do too. The holes throughout the flat pieces are not flat, They are pressed. and make it rigid.
    Just a shot of my front Artec kit and Ballistic Fabrication Diff Cover, metalcloak gamechanger arms.
Name:	2014-03-08 15.48.25.jpg
    I need to see this thing flex up close.
    We are going to have to take her off road.....Keep a close eye on your keys.....
    This might be the prettiest axle I've ever seen. The gold bars, skull on the diff cover... swoon.
    Im going to give snarf a run for his money.
    At the end of this month, Im going back to Rock Krawler to do a 3 link front and rear. Then Im going to POR15 every surface under the truck.
    Ill also be showing off a new artec bracket on the rear truss for the RK 3 link.
  8. #8
    Just realize that the POR15 effort is much more intense than the 3 link conversion. You should start a POR-15 thread. In my previous life/s as a Fiat enthusiast I'm all too familiar with the prep work essential to POR-15 function. It is extensive!
    Looking forward to that three link.
    This girl was POR-15'd inside and under.
