Results 1 to 10 of 55
    It worked. They had the door harness and the relay both wired to the trigger switch. Thanks for all your help. Next time you're over the mountains beers are on me lol
    Nice job!!! That is awesome that you were able to just look at it and realize what they did wrong.
    I will totally take you up on that beer the next time I'm over there! (even if it's like a year later, so don't forget me!!! grin.) In the same regard, if you're here in Spokane, just let me know and I'll be happy to buy you a drink.
    What killed me was I was very clear with both shops about NOT connecting to the doors wiring harness, and they both spent so much time on it I assumed they did what they were told. The minute I crammed myself down in the footwell I saw what the problem was (thanks to you of course). I'm not going to worry about the switch. If I need to disable the steps it can be done with the dome light switch. This is the perfect setup as is. Besides the buzz of course. Lol. I'll get used to it.
    Thanks again man. Keep on wheelin'.
    Kevin
    Kevin
    So BigKev, it's been a year since you did the dome light mod. How's it working? Have you come to love the sound of the buzz of the relay switch and how it's like a little 2 second warning to the steps being retracted?
    sounds great
    Hey Bro! How's it going? Actually that buzz went away after a few months- steps are still working great! Saw your post about the steps in muddy wheeling- I just turn mine off by rotating the switch all the way to the back, turning off the dome lights. Easy squeezy! Hope all is well with you.
    Kevin
    Kevin
    The buzz went away? That's crazy. The buzz is caused by the dome lights having the voltage reduced to create a dimming affect when turning off. Maybe you have a relay switch that has a magnet that is just not as sensitive to this. Maybe my relay switch was too cheap! (ha!)
    Ah yes, of course, if you are running strictly off the dome lights and can already control it, then my little solution would not be needed. I have wired back to the door signaling when the top/doors are on and I'll switch back to the dome lights when the doors come off.
    I needed a solution because our Jeep family grew. My daughter saved up enough money for her first Jeep and now she wants to go Jeeping all the time!
