Results 1 to 10 of 244
    Which Looks Cooler?
    Each unit does give the truck the air that something incredible is lurking under the hood.
    The Magnuson is very understated. Thats going to be their calling card, until you hit the gas. Here are the two grills side by side.
Name:	Magnuson Intercooler.jpg
ID:	139 Click image for larger version.
Name:	RIPP INTERCOOLER 2.jpg
    The RIPP unit is more "in your face". You could walk by the MAG and not think there was anything special going on. Complete Sleeper.
    With RIPP you can tell a mile away that your not dealing with the normal JK. There is a monster living under the hood. And that intercooler is the only warning you can see from a distance.
    Here are the full noses.
Name:	Magnuson Intercooler 2.jpg
ID:	141 Click image for larger version.
Name:	RIPP INTERCOOLER.jpg
    As far as picking a winner here, its going to come down to your personal taste. However for overall coolness, the victory in this category goes to RIPP
    Coolness Winner: RIPP
    Install
    We didn't install our RIPP unit, but we can pretty much see how it was done. We did the MAG unit ourselves in under 9 hours overall with an hour break in the middle.
    The RIPP install is the more invasive of the two. People say you can unbolt and go back to stock if you want. With the RIPP unit, its not quite that easy. there is some sections of the engine bay that need trimming to fit the pipes thru to the intercooler. You are not fixing that after the fact. So there will always be clues to anyone looking that the engine bay was modded at some point. The trimming isnt severe, but its there.
    You will also change the coolant bottle with the RIPP unit. Something else to hold on to if you thought you might uninstall in the future.
    Here's the finished product
Name:	RIPP JeepLab.jpg
    The magnuson install is borderline easy, and less invasive. You will cut some hoses, but nothing that cannot be undone later. It does have a flaw however. When you install the coolant pump, you'll see its low in the engine bay. About the same level as the bumper. This pump is water "resistant" but not "waterproof". So its a consideration you have to be aware of off road. We think they will relocate it in the future, or change to a waterproof pump, but as of today, its not.
    Installation Winner: Magnuson
    Finally! Been waiting for this one....Subscribed!
    Sound
    This is a tough call. But since we are comparing out of the box units, I have to do it as it is.
    Ill tell you right out of the box, its RIPP by a mile. You can barely tell that the Magnuson unit is installed, as "out of the box" like we are talking here, you would put your stock intake back on. The stock intake silences the pentastar. Here are some soundbytes so you can see the difference from one unit to the other.
    Here's the RIPP's sound bytes
    First, here is the drive by sound. Black Betty sounds like a fighter jet on the road. The whistling pentastar sounds like a jet engine.
    ** Sweet Pea is in this video, but she is not supercharged at the time. We used her as the stock jeep.
    Heres another one
    Now for the Magnuson unit -
    Just for fun, to show how terrible the stock intake is for muffling the fantastic noises that the pentastar engine makes, here is a video we did for the AFE Pro Guard 7 intake. You can hear the difference immediatly, and this is just the intake.
    As far as crowning a winner with only the gear you get "out of the box" with your supercharger purchase, RIPP wins easily, once you put an intake on the Magnuson unit, it might be a completely different ball game. (ill do it for fun)
    Sound Winner: RIPP
    after listening to those videos, we really have to get an intake on the Magnuson unit.
    Is the snow melted there yet? I cant wait for you to post the side by side zero to 60s.
    Ive got my finger on the trigger for an SC.
    Im going to wire the trucks up for the 0-60 this weekend both with the stock tires.
    The snow is melting. And it should be about 50 degrees.
    I need to figure out the weight differences between the trucks, as Betty is heavier and taller, Im going to put some extra weight in Sweet pea for an even test.
    I'll figure it out down to the ounce.
  8. #8
    Here's a comment from Gunner in our blog. -
    The Maggie looks like an A/C unit. The Ripp looks B/A. That said I would most likely spray them black to keep it low profile from thieves. I had a GMC Typhoon back in the day. It used the water to air. The unit needed lots of airflow to not get hot. The faster guys switched to air to air for drags and high speed stuff. I am looking forward to how it holds up during your first summer. I am betting on the air to air having cooler intake temps when your running in traffic. Plus the Blower is right on top of the engine where the ripp is in the air flow from the radiator. It is going to be interesting.
