Results 1 to 10 of 49
Thread: Ripp SC & CEL
    Dont know if this applies to you but there is a TSB I found for other pentastar applications with this fault. If this is the case I think you need to:
    Go to the dealer
    Return PCM to stock
    Have it flashed
    Install RIPP tune and send them the now new backup file to have their additions made to it.
    SUBJECT:
    Flash: MIL Illumination P0441, P0300, P0301, P0302, P0303, P0304, P0305, P0306,
    P0420, P0430, P113D, P113E, P0133, P0153
    OVERVIEW:
    This bulletin involves selectively erasing and reprogramming the Powertrain Control
    Module (PCM) with new software.
    MODELS:
    2012 (JC) Journey
    **2012 (JS) 200/Avenger**
    NOTE: This bulletin applies to **JC** vehicle equipped with a 3.6L engine (sales
    code ERB) built before November 15, 2011 (MDH 1115XX) or **JS vehicle
    equipped with a 3.6L engine (sales code ERB) built before December 16, 2011
    (MDH 1116XX).**
    SYMPTOM/CONDITION:
    The customer may experience a MIL illumination. Upon further investigation the
    Technician may find that any of the following Diagnostic Trouble Codes have been set.
    a. P0441 - Evap Purge System Performance
    b. P0420 - Catalyst Efficiency (Bank 1)
    c. P0430 - Catalyst Efficiency (Bank2)
    d. P0133 - O2 Sensor 1/1 Slow Response
    e. P0153 - O2 Sensor 2/1 Slow Response
    f. P0300 - Multiple Cylinder Misfire
    g. P0301 - Cylinder 1 Misfire
    h. P0302 - Cylinder 2 Misfire
    i. P0303 - Cylinder 3 Misfire
    j. P0304 - Cylinder 4 Misfire
    k. P0305 - Cylinder 5 Misfire
    l. P0306 - Cylinder 6 Misfire
    m. P113D - O2 Sensor 1/1 Slow Response (High Frequency)
    n. P113E - O2 Sensor 2/1 Slow Response (High Frequency)
    Updating the software will correct the conditions listed above.
    Junior Member Bullfighter's Avatar
    Aug 2014
    Northern WV
    Blog Entries
    1
    Quote Originally Posted by sajk View Post
    Go to the dealer
    Return PCM to stock
    Have it flashed
    SUBJECT:
    OVERVIEW:
    MODELS:
    2012 (JC) Journey
    (MDH 1116XX).**
    SYMPTOM/CONDITION:
    Thank you for the reply, it's much appriciated. I'll try it and see what happens.
