Here is how they work. With the Metalcloak Overline fenders (overland as well), you remove the plastic liner and replace with some precision bent aluminum pieces shown here in red:
I've powder coated mine matte textured black and they should be installed in about two weeks. I can get some better pics then. They seem like they'll keep the mud/muck out where needed while concurrently adding a ton of airflow.
No, they don't overlap. They simply cover the open areas that lead to the engine bay and components. The places they leave "open" are where the mud/gunk/salt will hit other surfaces like the tub, frame, etc. Not as much protection as a giant plastic bowl of a stock fender liner but better for air movement, access, etc.
I think those inner fenders from Metal Cloak would be good for heat reduction, but im not sure about how much heat is going out of the channels of the RKsport hood.
The hood takes the air and forces it down to the intake, which is fantastic for cold air, but for helping hot air escape im not so sure. The perhaps at high speeds, the hood would force the hot air of the engine bay out thru the inner fenders, and at low speeds, the hot air may escape through the intake to the rear vents.
My meaning is, you can see the large vents in the rear of the hood. You'd think they were great for heat reduction, but they are not directly open to the engine bay. They are connected to channels that lead to the nose, and to the intake.
So the difference between this RKsport hood and Deola's Heat Expulsion hood is that one sucks air in on purpose, and the other spits it out on purpose?
IT seems like it would have the same effect while driving with the fender liners. While air is heading in and down to the intake, the hot air that it displaced would have more freedom to exit the engine bay.
I could see how, at idle and while not moving, the heat may not have a way to to up and out of the hood through the scoop. But still, that scoop isn't doing a damn thing to bring in air when you're not moving forward anyway. Right?
