Results 1 to 10 of 12
    It might be worth mentioning that if you put a new spring in there, make sure the new spring doesn't fully compress and bind up before the pedal reaches the end of its travel.
    yikes, imagine the springs bind up an the pedal stays down? that is scary.
    You guys are brave, screwing with the gas pedal
