Plan is to strap it to a dyno and see what this slug is putting down to the ground
Did you get dyno results before the Sprintex install? If not, then it's hard to know whether it would be valid to compare to other people's dyno results.
I did not, I wish I did though. No way I am taking off the blower to see the before and after results. I plan on running E85 so I'll compare power results vs Gasoline.
