My tread is 9.5 inches, the tire is a little over 12.
I use a lot of pressure, so they are tall and thin. Would probably be wider with a wider rim. My rim is 8.5
Okay, thx. I just measured mine again (as it had been a while) and my treadblock is 10", and the tire overall is 12.5" to 12.75" (eyeballing it.) My rim is 10". What do you think the KM2's would flatten out to with a little lower pressure and a 10" rim?
You are for sure right on your research about those KM2's. Based on all my research, I really do think they are the best tire out there for all around every day use. I just wish they made them in a 13.5" wide. 35's in 12.5" look good, but add a little height to them and they get a little narrow looking. I've found some 37"x13.5" (Toyo's, etc.) but DANG do those tires get heavy quick, some upwards of 90+ lbs! Yours are seriously only a few lbs heavier than my Baja ATZ.
