Results 1 to 10 of 94
    Im about to strip my SC to install the high alt pulley. Im going to take it apart and look inside. Will report back.
    I wouldn't open up a supercharger unless you need to open it to change the pulley. Disconnect your PCV tube from the supercharger and look inside. Is it dry? Mine isn't. After 10k miles I got a finger coated with oil from inside the tube. I'll pull my PCV tube and see if I can get a good pic of what it looks like.
    Here's a good white paper on PCV oil separation.
    http://www.conceptualpolymer.com/PCV...oval%20102.pdf
