Originally Posted by WhiteRavenRR Start with the front corners and then work your way back from there. Tuck the Ball up into the front corner plastic housing: Installed product: I see the spider ball sticking up in the back. Did you pull it under? You attach it ball up, Then pull it around so the ball is down inside.
