Results 1 to 10 of 12
    I'll have to try to find it on their site. I need to get some measurements to see how it lines up with the tabs on my LOD Armor lite front bumper.
    it mounts from the winch mount. The bolts holding your fairlead on.
    That would work perfectly. Then I could remove the tabs on my bull bar or put them to alternate use.
    Here is the ENGO 12 inch LED light on the JCR off road winch light mount
Name:	Engo LED light.jpg
    It attaches to the bolts that hold your fair lead on.
    I see how that will work. Out of curiosity where did you run the wires? I was thinking about bringing them down and in with the winch wiring. But more immediately how did you cleanly run the wire close to the engo bar? Don't want a wire just flopping around up front.
    When it was installed, I ran them down the arm of the mount (zip tie) and into the hole in the JCR bumper where the winch wires go. (another zip tie)
    Then up to the spod.
    it was very clean. And the light is BRIGHT.
    Sooooo a 12 inch on the front bumper? or the flood bumper lights on each side? Preference?
    I think its more about style, unless you get really cheap flood lights. I might go with the bar. Every jeep has flood lights. And you can never really use them.
