Results 1 to 10 of 55
    Timmy could you enlighten me as to how you connected your relays? I assume that the steps works when the doors are connected and also work when the doors are off.
    Quote Originally Posted by Charlie View Post
    I'm not sure I follow exactly on your question? I thought my write-up gave enough detail on the relay I used, the wiring I used, the connectors I used? Happy to help, but maybe get a little more specific if you would.
    And yes, this solution will work with doors on or off. The problem with this solution when the doors are on is that AMP distinctly designed their solution to lower the steps only on the side that the door was opened on, and to retract as soon as the door is closed. By connecting to the dome lights, this solution will lower the steps on both sides whenever any door is opened (including the rear tailgate) and they will stay down until the dome lights go off. So as such, when you have your door and top on, it might appear the operation is a little goofy compared to what most people are used to seeing, however, the actually usage will still operate at the right time when you need them down to step on them. If you get the right type of splice though, it would actually be a snap to swap them from the relay solution here back over to using the wire for the doors. AMP included a nice wire tap that I had not seen before, that if utilized for both solutions (you'd have to buy more of course,) would allow you swap rather quickly, OR, you could get really fancy and put in a toggle switch that flip/flops between which solution you would use, that would be SAWEEEEEEET! Shoot, I may just do that. In fact, I may go so far as to put the button in the center stack set of buttons. If you did this, then in theory you could get away with just installing a single relay switch to control both steps instead of the two that I used (one on each side) and instead put your effort into installing the button. Ooooh, oooohh, ooooh, even better, you could get a lighted button that lights when the steps are down when used with the relay, then you'd have a nice visual (in addition to the dome lights being on) that your steps are down.
    Switch wiring
    Timmy; do you have the wiring diagram to using a 7 pin Carling switch along with the relay to be able to switch back and forth from key fob to "Standard" step operation
    Thank you in Advance
    Quote Originally Posted by MrWayneD View Post
    Sorry, I don't, but it would be cake to do. Basically put a switch in place that switches between using the dom light for the signal (via the relay I described earlier) or using the door open signal that AMP has you tap in to. You could accomplish this with a very simply three pin switch. Center goes to the AMP control head, top lead to dom relay, bottom lead to door. If you wanted to get fancy, you could put in a three position rocker switch that has an on/off/neutral setting so that when it's in neutral it is not connected to anything so that the steps would not lower at all (say if you were off-roading and jammed against a rock and didn't want the steps to retract at all if you opened the door.)
    At first I thought I would want to move my signaling back to the doors and off the dome light when I put the doors back on. I've learned, I don't care. Dome light comes on when I open any door, steps retract, which is all I care about. The difference for me is that both steps retract versus just the step on the side the door opened. No big deal for me, it doesn't bother me, so I just left my wiring in place.
    Hope that helps.
