Some tire images I had on my phone.
Keep These coming. Im going to be in the market soon. Maybe show some ATs
Im tire shopping.... Anyone with Goodyear MTRs?
Nitto Terra Grapplers
These are on a 2013 JKU Sport S, it totes a soft top, AEV steel front and rear bumpers with their BB and Geometry Control brackets. The tires are sized P285 70 r17 s.
Mud- These tires hold their own in mud, especially if aired down. Wet muddy fields and trails aren’t an issue until you get several inches deep. In red clay or swamp mud, throttle control was the key to keep momentum going. You’re going to have to spin through it.
Snow- Great here lately on all the snow covered roads. Dry powdery snow isn’t a worry, and wet slush wasn’t an issue either…even the 7” that got dumped on us the other day. I feel the weight of the rig really helps in the snow and a light 2-door may want to air down a bit if you’re planning on spending the day in the snow.
Rain- These tires channel water very well and I could only get the ABS to take over to early if I stood on the brakes in standing water. Highway speeds, lane changes, and braking were all great.
Sound- These tires are just as quiet as the stock Jeep sport street tires at all speeds, pretty impressive.
Ride and Braking- These tires took anything I threw at them on dry roads at 32 psi. Cornering, accelerating, braking, quick moves all were within the terra grappler’s abilities. Off the line the RIPP made sure that you left your mark…about 60’ of it.
I would recommend these tires to someone who uses their Jeep as a daily driver, and sees moderate off road conditions. Aired down you can push them a little farther than you would think.
Pros- Great bite for an AT. Long wear life, my friend got 65k miles on his 07 JKU with these.
Cons- Not a ton of sidewall bite, but this is an AT tire. I felt myself giving this tire a bad rap at first, but I had to step back and stop judging them off road against my mud grapplers. After that I was able to give them a better review for what they are made for.
