Results 1 to 10 of 19
    Thanks. It's good to be here. With the liners out it could use a bit more trimming to even it out and make it more flush.
    Show us a pic of the whole truck!
    Ask and you shall receive:
    are those flares custom cut?
    Give us threads on both please, Id love to see the cuts up close. Im a strong advocate of cutting flares.
    And the bumper also....
    Make sure the sun is at your back with pics, the dark of the grill will make the flares and bumper difficult to see the detail.
    I just cut my seem.
    I got some dirt in it, then washed it, so that foam inside was wet maybe... then I packed it with JB weld,
    Am I going to rust my body out?
