Hi,
On Friday i went to dunes with my JK . It was fun, but i experience a high vibration on road. Check the wheel balance all ok. Check the shaft (transfer shaft bolt were loose ) and then i saw this ......
Ugh. are you sure all your pipes are geometrically correct? i remember it was tight getting everything in.
and this is a side question, as its answer has no bearing. how hard were you wheeling? high speed? big twist? did you hear a "CLUNG" sound at any point?
