I'm interested in what happens with the coolant overflow reservoir. Do you have any pics or thoughts to share on that? Is the new location reasonably accessible for checking the coolant level?
The coolant tank is black (knew you'd like that) and it mounts near the front bumper where you can check it easily. My mount was a bit more of a challenge because I have a stubby front bumper and a front skid plate. We mounted it at a slight angle and it is behind my skid for protection. Checking it is not as easy as a stock bumpered JK but it really isn't too bad to remove two bolts, drop it, and inspect.
Skid is off in this picture so it looks more exposed than it is.
FIRST DYNO CHART
This was the best run today. Here are some notes you need to be aware of.
- The stock line in this chart is not Jesse's Girl, Its Sweet Pea's stock dyno line. Sweet Pea and Black Betty were dyno'd years apart (stock) and came out in the exact same spot, so I consider the line a standard.
- Humid summer day
- 4.88 gearing. - This shouldnt alter the line as far as power to the ground vs RPM but JG is geared.
- Stock Tires. All our dyno's to date are on stock 255/75R17 BFG Km1s.
