Results 1 to 8 of 8
    You can always run a set of wheel spacers to push your factory rims outward in the meantime until you decide to purchase new wheels. Keep in mind that 18" rims won't really give you a whole lot of sidewall.
    Also some tire companies won't touch your tire/ wheel combo with spacers installed. If you have to get a flat fixed it would be best to remove the tire for them to fix it. Call your local tire shops beforehand to confirm their protocols regarding spacers.
    I would recommend a higher end spacer from a reputable manufacture for a good quality set. Don't skimp for cheap ones.
    Agreed. Some will say spacers are dangerous. The x-factor here is that the stock wheels are 18s. Big tires for 18s will be expensive. If you look at the difference in tire price for 18s vs 17s you'll find a big chunk of the budget required to buy new 17inch wheels. (with correct backspace so you won't need spacers.)
